Thread: How much CH until I stop using Cal Hypo?
    Jun 2015
    Bergen County, NJ
    7
    It's been a couple of weeks now since I've converted to the trouble free method with bleach instead of pucks/cal hypo but I still have a big bucket of cal hypo left in the shed. My CH is around 350. I figured I would just finish it up and then stick only to BBB. Is 350 too high to continue using cal hypo? What would you guys say is the upper threshold? Thanks!
    35K
    In ground plaster
    TF 100
    DE Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,015
    Re: How much CH until I stop using Cal Hypo?
    You're there already. Just make sure the bucket is sealed up tight and save it for opening next season. You'll no doubt lower the water level when you winterize, right? When you refill next spring, your CH will be lower and you can use it then.
    Jun 2015
    Bergen County, NJ
    7
    Yup, that's correct. Thanks.
    35K
    In ground plaster
    TF 100
    DE Filter
