Thread: Algae Sludge
    Jul 2015
    Smiths Grove, Ky
    1
    Algae Sludge
    I have an Intex 24'x52" above ground pool with a sand filter and pump. This is really bad in the bottom of the pool, can I use the backwash to vaccum most of this out or will it hurt my pump?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Algae Sludge
    If you're going to backwash sludge, use the Waste setting on your valve. All water and sludge vacuumed will go straight out of your waste/backwash line and not clog your filter.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
