Thread: Poured concrete pad or prefab
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    It seems like all of the builders we've spoken to use the prefab slabs like air conditioners sit on for the equipment pad. One guy volunteered that they could pour a slab if we wanted them to, and I suppose I could ask that of any builder we go with. But I'm wondering, does it matter one way or the other, as long as there is enough room on whatever pad they go with? Is it worth asking for (and probably paying more for) a poured slab?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,181
    Re: Poured concrete pad or prefab
    I would just like to see room around each piece of equipment to work. A prefab slab is going to be smaller and thus the piping is going to be compact, not lending itself well to repairs or additions in the piping.
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    As long as the base soil below the prefab pads is properly bedded with a packed gravel or "class 5" or "class 2" material, it should be fine. Prefab slabs can actually sometimes be less prone to cracking than poured slabs, depending on the expertise of the installer. With a poured slab or a prefab, the base material preparation below the concrete is very important. Make sure if it's prefab, it's not undersized. Should be able to stand on the slab next to the equipment, especially near pump and filter.
    Isolated Spa - 345 Gallons
    JamieP's Avatar
    May 2011
    1,135
    Thanks, guys. At least now I know how it should be done if they do end up using the prefab slabs. I'll be sure to ask how they do it when we pick a builder.
