Thread: Pouring the Concrete Collar on in ground pool
    Jul 2015
    Sault ste Marie, Ontario, Canada
    21
    Hi there,
    We are installing a 22' x 44' rectangular inground swimming pool (Steel walls, vinyl liner). We have just put the walls up. To level the the walls we have used patio pavers and shims under some of panels. This has created a significant gap between the the pool shelf and the walls in those areas. We will be ready to pour the concrete collar soon. Our question is: how do we keep the concrete from seeping into the pool? I.e. what should we use to block or fill those gaps to keep the concrete collar on the outside of the pool?
    22' x 44' rectangular IG vinyl liner swimming pool with SWG, 10' depth in deep end, 44,000 gallons. Pump: Pentair Superflow 1.5 HP High Performance Pump. Filter: Pentair Sand Dollar Filter. Location: Ontario, Canada
    May 2015
    kingston springs, tn
    102
    Re: Pouring the Concrete Collar on in ground pool
    How large are the gaps? What is significant? In most cases packed 3/4 limestone gravel.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    Jul 2015
    21
    The gaps are generally 1.5 to 2.5" but we do have one spot that is 3.75".
