Thread: Bad storm 2 weeks ago, made me take chlorinator off and now???
    Kannapolis, NC
    89
    Here in Kannapolis NC a couple weeks ago we had a bad wind shear come thru, and after said shear I look outside and there is water shooting up from pool equipment. Dont know how but the plug in the chlorinator got pulled out or pressured out. After this I went out and cut it loose and went to Lowes and got a pc of PVC pipe and now my Pump will not stay primed. It will do fine for a couple hours but always gets real loud and I need to cut off. I took the pump loose and nothing in propeller or whatever its called. I am lost can someone offer some advice.
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Re: Bad storm 2 weeks ago, made me take chlorinator off and now???
    Can you post some pics to show us what you're talking about?
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Did you cut the ends of your pipes square, chamfer the ends, clean, ensure you fit up is good, then prime all pipe ends and inside of fittings?
    Probably most importantly, did you apply cement to both the pipe and inside the fittings (both sides have to have cement) then wait 30 minutes for it to cure more like an hour before you turned the system back on?
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Kannapolis, NC
    89
    hey my bad, I went back out there and thought for a second and haven't checked the pump basket, whole lotta junk in there and back to norml
    _________________
    My Pool:
