Results 1 to 7 of 7
Thread: vinyl liner feels rough in shallow end walls??
    mostly in the shallow end. the vinyl liner feels rough from about half way from the top of the pool and to about half way to the bottum of the pool wall. ie the mid section of the pool wall. any ideas why this is??
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: vinyl liner feels rough in shallow end walls??
    Could be an old liner getting rough. Could be calcium scale. Got some test results?
    Calcium is at 30 ppm liner I believe is about 5 years old. I would have to look for bill as it was installed by previous owner
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    DFW, TX
    24,502
    What about PH and TA? 5 years isn't old.
    Quote Originally Posted by pooldv View Post
    I don't have those on hand right now but r they are within normal range
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    ^i was trying to piece together your history to give a coherent tip about your liner wrinkles.
    I've seen a few brief posts without test results. From what I can gather, you mentioned aging added too much chlorine at some recent point after 3 slams, and posted a question about pucks.
    First off, unifying your questions in a single thread might help us help you better. Perhaps a mod could merge them.
    Secondly, for ANY of your liner questions, we need to know the "event history" that led up to the wrinkles/roughness, etc.
    Thirdly, you mentioned buying and using pucks somewhere in there...pucks, high cya and low ph can when combined cause a liner to waterlog/absorb water and cause wrinkles. But so too can using too much chlorine, which is why we have specific parameters that rely on precise testing.
    So I guess my question is, do you have a test kit, and do you plan to follow TFP methods? If you do, please post up your test results so we can help you at least identify the possible cause of your liner issue and give suggestions to avoid exacerbating the liners condition moving forward.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    I don't have a test kit yet. We had a heavy rain fall. The day after that's when I saw the wrinkles in the shallow in and one buy the shallow end jet. Since then the wrinkle has moved to the middle of the deep end and use a shape of a bubble in the deep end. The bubble has occurred exactly in the deep end where there is an even spot in the pool. When I first got the pool it was a 6-8" uneven spot in the deep end I'm assuming there must off been a drain there before
    The only reason why I noticed the rough walls at some spots is cause I swam in it for the first time 2 weeks ago. So I am unsure if the roughness was there before hand or when it occurred. The pool has been open since late June approx.
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
