Thread: Help Me!!!
    Jul 2015
    Miami/Florida
    1
    Help Me!!!
    I just purchased a 22ft. pool above ground from Walmart. Just found out I need to put chlorine in the pool. What other supplies do I need to keep the pool safe for my grandchildren.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Help Me!!!
    Welcome!
    Pool School - Guide for Seasonal/Temporary Pools should tell you what you need to know.
    Some stabilizer aka Cyanuric acid aka CYA, some bleach, and a small test kit will get you started. The test kit will tell you if your pH needs to come up or down, and that will determine what else you need to add.
    Other worthwhile pool school articles are
    Pool School - Recommended Pool Chemicals What does what and how to add it
    Pool School - PoolMath How to use poolmath top figure out how much to add.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Help Me!!!
    Welcome to TFP! Congrats on the new pool.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Help Me!!!
    Welcome to TFP!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Help Me!!!
    Hi Brenda!!!
    Welcome to the forum, I am from Miami too, fire any questions, you are receiving good advice already
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
