Thread: Understanding valve positions
    Jul 2015
    Thousand Oaks
    1
    New owner. What positions do I keep the valves in when not in use? I have an elevated spa with a waterfall that overflows into pool. Can I just keep the Suction on pool and Return on the spa. Not sure why it was always pool for both suction and return.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Understanding valve positions
    I leave mine set so it's 100% suction on pool and 80-20 pool-spa on return. If you have a bad check valve, you may see the spa drain back into the pool overnight.
