Thread: Deformed Piping Near Heater Outlet - Melted?
    Jun 2013
    Austin, TX
    27
    I've read that schedule 40 PVC can melt close to the heater outlet, but never it expected to see it as my Aqualink has a "heater cooldown" enabled. Today, while backwashing, I noticed a deformity my pipes (attempted to capture it in the picture below). I assume it has gotten too hot. I have confirmed that Aqualink still kicks in the cooldown period after the heater has been on and increases the variable speed when the heater is on.My questions:
    * How urgent is it that I get the deformed pipe replaced?
    * Is there anything else it can be other than the heater melting the pipe?
    * What can I do to prevent recurrence?
    Rob
    15k gallon, IG plaster pebble surface, single speed filter pump, sand filter, Polaris 280 cleaner w/ PB40 booster, AutoPilot Nano+ w/ RC-28 cell.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Deformed Piping Near Heater Outlet - Melted?
    That almost looks like flex PVC on the vertical section. Are you sure it's melted and not just collapsed a little from being too long?
    Jun 2013
    Austin, TX
    27
    I'm not sure it's melted, just my best guess. But it doesn't feel flexible at all.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Defective pipe? A thinner wall section bulging?
    Jun 2013
    Austin, TX
    27
    Again not sure. It's hard like any other pipe section. It doesn't deform if it give it a good squeeze.
