Results 1 to 7 of 7
Thread: First Test with TF100
    Jul 2015
    Cartersville, GA
    10
    After dealing with local pool stores for the past 12 years I had enough. At the beginning of the season I started using generic chemicals (bleach, muriatic acid, baking soda, etc). That worked just ok but I knew there should be more. Started reading here and ordered the TF100. Below are the results of my first test.
    PH 7.2
    FC 4.5
    CC .5
    CH 125
    TA 80
    CYA 40
    Conditioner is the only pool marketed chemical I have purchased. Is there an alternative or am I stuck with buying it as a pool product?
    Combined Chloramines - Am I correct in saying this is the only issue? Looks like I need to get the free chlorine up to 16 to get the CC to below .3ppm.
    Really impressed with the TF100 and just how easy the kit is to use.
    27' Round Vinyl Lined Above Ground, Hayward Power-LX 1.5hp pump & Dream Line Sand Filter S190TSCP
    TF100 Test Kit / Tiger Shark QC
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: First Test with TF100
    CC is fine as long as it is .5 or less (1 drop only to get back to clear).
    What type of pool do you have (plaster, vinyl, or fiberglass)? If it is plaster or fiberglass your CH is low.
    By conditioner, do you mean stabilizer or CYA? If so then yes, that's the only thing that you need to buy as a "pool chemical".
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Jul 2015
    Cartersville, GA
    10
    Vinyl liner....and yes, CYA
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Those numbers look great! Congrats on the new kit and taking over your pool.
    Your CH is fine for vinyl. I get my CYA at Lowes in the pool section near the garden section.
    All you need to do is keep PH between 7.2 and 7.8 and maintain chlorine at target or a tad higher.
    Happy
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    What you need to do now is
    A few days maintaining the proper FC level will eliminate any lingering CC. Unless the water is green or cloudy. Too often we concentrate on test results and omit the ultimate test: how does the water look? Nobody but us cares about test results. The rest of the world is more impressed by crystal clear sparkling water that doesn't smell and doesn't dry skin or burn their eyes.
    Oct 2014
    Magnolia TX and Watford City ND
    40
    Welcome to TFP and thanks again for my seat springs!
    25K IG gunite pool / PebbleTec plaster / 2HP Hayward 2 speed pump / Hayward 525 SQ/FT SwimClear Cartridge filter / Tiger Shark QC robot / TF-100 test kit / Stenner pump X 2 - Chlorine and Acid
    Jul 2015
    Cartersville, GA
    10
    Thanks for the info on the CC. I'll let it ride a couple days and see if it comes down to 0
    The water is nice and clear, thought I had mentioned that.
    Quote Originally Posted by pcool69 View Post
    HA! Small online world. Glad you like them. I know there is no way I would still own my 1025r with the stock springs.
