Results 1 to 7 of 7
Thread: Completed first SLAM....
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    ....and have gloriously crystal clear water! I love TFP!
    Just tested tonight:
    pH: 7.8
    CYA: 40
    TA: 110
    FC: 16 (still drifting down)
    CC: 0
    TC: 16
    CH: didn't test, but it's been pretty consistent around 200 all season.
    We got a TON of rain over the last few days, and the water level is almost to the top of the skimmer by the pump...it IS to the top of the other skimmer (for another post)..
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Aug 2013
    Arab, Alabama
    422
    Re: Completed first SLAM....
    Congrats! I'll venture to bet our pools look better than many in our area and it is cheap!
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Great post!
    Congrats on a successful slam. Isn't that crystal clear water nice?
    Feels good on a hot day too!
    Dont worry about the CH..vinyl pools dont require any CH maintenance. Just make sure it doesnt get crazy high, and you're good.
    I test my CH once a year, just because.
    Quote Originally Posted by wjaneala View Post
    pH: 7.8
    CYA: 40
    TA: 110
    CC: 0
    TC: 16
    Divin Dave,
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Yes, and after I read this article today, I am NEVER getting in a public pool again. **warning: this article is gross!**
    Crypto in swimming pools: Swimmerst kill.
    Wendy
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Not reading that!
    Congrats on the sparkly pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    So it took, what, 10 days? Less?
    Have you tried tossing a quarter in the deep end and see if you can call heads or tails from outside the pool?
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    About six days I believe, but I'd have to check my dates to be sure. Yes, and I can!
    Wendy
    TF-100 Test Kit
