Thread: How to fix leak?
    Nov 2014
    Palm Desert, CA
    99
    How to fix leak?
    We have a small leak coming from the top part of the pump where the electrical wires are coming out of (see photos). Is this something we can easily repair? I'm thinking we unscrew the top and use plumbers tape?
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Jun 2014
    15,082
    Re: How to fix leak?
    I suspect you are probably correct. I would try some Teflon tape first, and if that doesn't work, some plumbers goop. There are different types of goop for water applications. Lastly, if neither of those work, get a big hammer. Good luck!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    try plumbers putty, the liquid kind with the brush inside (same can just like the glue) they have it at lowes and its good to 10,000 psi for liquid
    its right next to the plumbing glues and pipes..
