Results 1 to 10 of 10
Thread: Skimmer issues
    Jul 2015
    Mount Sinai NY
    6
    Arrow Skimmer issues
    Having a hard time posting this but after the third time any input on how to handle pavers getting debris in pool skimmers etc when doing paving job. Do I shut off filter cover pool suggestions?
    Apr 2015
    Quinlan, tx
    811
    Re: Skimmer issues
    What kind of debris and are you worrying about it getting into your filter?
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Jul 2015
    Mount Sinai NY
    6
    Re: Skimmer issues
    [QUOTE=Pogueld;863346]What kind of debris and are you worrying about it getting into your filter?
    Cement dirt rocks due to preparation of the soil for pavers to be installed.
    In ground pool owner sand bottom. Measurements of pool 16 X 32. Recently installed a new liner, hayward super pump VS, Aqua Plus chlorination with salt and a solar heater. In process of installing pavers around pool have a diving board and steps with jets.
    Apr 2015
    Quinlan, tx
    811
    Re: Skimmer issues
    Are they small enough to go through your skimmer basket?
    Aug 2014
    Shallotte, NC
    693
    Re: Skimmer issues
    Use a skimmer sock.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Skimmer issues
    I second skimmer socks
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Skimmer issues
    Quote Originally Posted by ewkearns View Post
    Use a skimmer sock.
    +1
    I'm in the middle of a return repair with the pavers around the skimmer being removed- sand & rocks all over the place
    Plus my paver guy just re-sanded the whole job @$%^&
    The Skimmer basket should get most of the big stuff & a sock will get most of the small stuff
    I use 1Gal paint strainers, go to Home Depot and pick up a pack
    Trimaco 1-gal. Elastic Top Strainers (2-Pack)-11572/36WF - The Home Depot
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Apr 2015
    Quinlan, tx
    811
    Re: Skimmer issues
    Excellent suggestions!
    Jul 2015
    Mount Sinai NY
    6
    Re: Skimmer issues
    Thanks for the suggestions
    Apr 2015
    Quinlan, tx
    811
    Re: Skimmer issues
    Let us know how it turn out.
    Lisa P.
