Results 1 to 8 of 8
Thread: kreepy krauly thoughts
    Anyone have a kreepy krauly? What do you think
    13000 gallon fiberglass, cartridge filters pentair Intelliflo Variable speed Programmable Pump separate booster pump solar panels on roof
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: kreepy krauly thoughts
    Based on what I've read here at TFP, most folks prefer robots or pressure side cleaners over suction side cleaners. Have not used a Kreepy Krauly myself though.
    Isolated Spa - 345 Gallons
    38,245
    I am not sure I have seen that pressure cleaners are preferred over a suction cleaner (certainly not a boosted pressure cleaner which is a waste of electricity).
    I think there are better suction cleaners than the KK ... namely ThePoolCleaner that I now use.
    Here is info on the various cleaner types: Pool School - Automatic Pool Cleaners
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I've used a Kreepy Krauly for 20 years. Overall I like it, but don't have any experience with other methods for a comparison. If you get a Kreepy, also get the Leaf Cannister that goes between the Kreepy and suction fitting.
    Things I don't like about it are:
    1. Sometimes it get's stuck on the stairs and I have to pull it off. This happens once every few days.
    2. I only run my pool 2 hours a day, so Kreepy may not completely clean the whole surface in 2 hours. When I swim (daily), I disconnect the hose from Kreepy and use it to suck up any missed debris.
    Overall, I'm happy with it.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Quote Originally Posted by epro05 View Post
    Thank you that's what I wanted to know, as for pressure side, I don't have a booster pomp so that's completely out
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Another really good thing about Kreepy is that it only has 1 moving part, and I've never replaced that part. I've replaced the flat circular part at the bottom and the flappers just above that, but replacement parts are easy to find online.
    If you decide to get one, check out the online prices (e.g. Amazon). Much less money than getting one at a pool store.
    Oct 2011
    Minnesota
    164
    I have one also, but we have a cover that goes on the pool that is used when we are not swimming. We will only use the cleaner once every 3-4 weeks and take it out of the pool when not in use. It works good, but the random pattern misses a lot of spots unless you run the cleaner for hours.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    May 2015
    Chickasha, OK
    184
    My parents used a Kreepy in our pool all through my childhood (of course, back then there weren't too many options for "automatic" pool cleaners...).
    I "inherited" my parents' old Kreepy and their "new" Barracuda when I bought my house. I took them both apart and discovered they needed new diaphragms. Ordered up new factory replacements, and the Kreepy just wouldn't run right. The Barracuda did great, except I could never get it adjusted/weighted correctly -- it would either sit flat in the shallow end and be "toe up" in the deep end, or flat in the deep end and "heel up" in the shallow end. The new diaphragm lasted about 2 weeks. The replacement I bought after that lasted maybe a month.
    I also always had trouble with the Kreepy and Barracuda sucking air. Replaced the hoses (not a cheap endeavor...) to no avail. The leaf canister was a major contributor, as well -- I just never could get mine to sink and/or seal up like it should.
    Maybe those are unique problems of mine (I wasn't quite as "into" pool maintenance, and certainly wasn't a TFP'er at that point)...
    Regardless, I switched to a Hayward TigerShark QC last summer and have never regretted it.
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
