Results 1 to 12 of 12
Thread: Pool anxiety
    Jun 2015
    Raleigh
    357
    Pool anxiety
    Having just completed my first SLAM on our brand new pool I've let the FC levels drop to 7 FC. I've cut my pump schedule back to 12 hours and put 200 lbs of salt to bring my levels up to 3500 using a drop test. Im dosing in the final CYA for a level of 70. I know everything is right but does anyone else get anxiety about FC levels in the 4 to 6 ppm range? Lol. I'm so used to keeping my new pool at SLAM levels this low FC and not monitoring every few hours is foreign to me. It's like I don't want to break my baby and I'm acting like a nervous momma.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jun 2014
    15,211
    Re: Pool anxiety
    Many of us ride our FC slightly higher than the target FC. We learned over the season that the pool just needs a little more FC to stay "healthy" and ensure it never drops below the target. I myself try to never rely on the mimum FC. I worry that the stress of heat, sun, and swimming is too much for that low FC to handle. It's good you are so proactive. Stick to and trust your own testing results and watch your water. You'll do fine.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Pool anxiety
    I think it's awesome that you have a brand new pool and that you've found this site at the same time. Your new pool should never have to get sick.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Re: Pool anxiety
    hehe. I'm the same way. My pool should stay around 4-6 but really I keep it around 7-8 because it makes me feel better. How was the swim party???
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Jun 2015
    Raleigh
    357
    Re: Pool anxiety
    It was great Sandra. We had about 60 guests...15 of those kids. I was expecting a huge loss in FC but through the course of 5 hours dropped only down to 10. Everyone was congratulating throughout the night on such a beautiful clean pool....I blabbered all night long about pool chemistry..lol
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Re: Pool anxiety
    I SO know what you mean! I dose mine just over the max for my CYA at night (so it can work all night long) so I am sure there is plenty for all day. I do NOT want to take any chances. LOL
    DO what feels good. You will learn your pool needs and wants. After a while you will even be able to tell where your PH is BEFORE you test! I still test to make sure but.........I am almost always right!
    Kim
    Apr 2015
    Quinlan, tx
    811
    Re: Pool anxiety
    YES!!! I am still a nervous pool mama! Like others, I have found, that I have a better chance of not dipping below 4 if I keep my FC between 6-8. With my pool, I just never know when a critter will find it's way into the skimmer (frog, rabbit, rat, etc) so I've had a few close calls where I've tested FC in the evening and it's been at 1.5 or a 2.5. Of course I panic . , I have an SWG, but I add bleach to get it back to 6, do an OLCT, and so far it's been good. I am slowly learning my pool personality and what it needs. You will too. If you're like me, you definitely don't want to end up in another big SLAM.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Pool anxiety
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Pool anxiety
    The only reason my pool FC is under 10 ppm is so I can test PH. It is nearly always above 8 with 70 CYA and spends a lot of time at 10ish because we swim a lot. Hours every day.
    I got lazy after vacation a few weeks ago when the temp went up and swimmjng went up and I tested FC was 1.5! Added bleach got in and saw algae for the first time in years! Ran FC to upper 20s, just under shock, and brushed every day for a week and it is long gone. But we swam every day for a week and a half in 20+ chlorine and it was not even noticeable. We did kill a couple of frogs every day that week, none before and none after. Weird.
    Jun 2015
    Raleigh
    357
    Re: Pool anxiety
    Speaking of ph...I just ran the full battery of tests as I'm leaving for a few days and want it perfect for the wife and kids...the numbers
    FC 6
    CC .5
    Salt 3800
    ALK 80
    CYA 30 and expect to climb as I added stabilizer for 70
    PH however dropped to 7.2 from 7.5 yesterday evening.
    Does CYA or salt lower PH...I added those two today. I threw in some dry PH up I had for the hot tub to bring it back up. Just curious why/how it could drop .4 in 24 hours.
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Richard320's Avatar
    Jan 2010
    19,046
    Re: Pool anxiety
    Quote Originally Posted by robertmee View Post
    FC 6
    CC .5
    Salt 3800
    ALK 80
    Check Effects of Adding Chemicals in poolmath. CYA will lower pH a little bit. It will only be a rough estimate.
    DFW, TX
    24,502
    Re: Pool anxiety
    PH is ok between 7.2 and 7.8.
