Results 1 to 7 of 7
Thread: Sand Filter and DE
    Apr 2015
    Quinlan, tx
    811
    Sand Filter and DE
    If adding DE to your sand filter, would you expect your normal PSI to run higher from here on out? If my normal PSI is 10, would it also be 10 when I'm using DE?
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Sand Filter and DE
    If you follow the article Pool School - Add DE to a Sand Filter your normal PSI will probably be above 10 and probably 11. And it will rise as it gets dirty, just like it does without it, but faster. When you backwash, it goes away and you need to add more DE.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Well, you only want to add DE in small amount that only causes the filter to rise 1 pound more. If you add too much it will definitely make it rise too much.
    Pool School - Add DE to a Sand Filter <--Link to article telling how to add DE to sand filter
    Apr 2015
    Quinlan, tx
    811
    I did follow the directions in adding the DE. I just wanted to be sure that I wasn't backwashing too soon with the addition of the DE so needed to clarify my understanding.
    As usuall, thanks for the help!
    Thank you, I did follow these directions so I was just clarifying that the PSI would stay at that level and not go down. I'm not as comfortable with the equipment/techinical decisions
    Thanks!
    Quote Originally Posted by YippeeSkippy View Post
    Apr 2015
    Quinlan, tx
    811
    Another question on same topic? Do you find you need to backwash more often with DE in your sand filter?
    Jan 2012
    7,368
    I don't notice any additional need to backwash. I *might* only backwash once or twice in 6 months...(my pool doesn't get much in it because of the autocover) but when I add DE the water does seem to sparkle more. And remember that a slightly dirty sand filter works better than one overly-backwashed .
    Apr 2015
    Quinlan, tx
    811
    oh wow! Well we don't have a cover. Our pool is in a rural area, we have lots of trees and debris that gets blown in, plus some dogs that love to play in the pool, and a critter every now and again. I usually backwash once a week, sometimes two depending on the weather. I only backwash based on an increase in PSI and the water is usually pretty dirty when I do. I was just wondering if I needed to be watching the filter more carefully.
    Thanks for your feedback!
