Thread: Equipment pad NOT level...will it be a problem?
    stdenpi1's Avatar
    Jul 2014
    Warwick NY
    11
    Hello everyone,
    My PB installed all the pool equipment, Pool is about 4 years old now. I just noticed that the equipment pad is not level. I think is must have settled over time. The PB put 3/4 stone under the pad. It's to the point where the heater and DE filter are about a good 1/2 off level if not more.
    Do you know if this would cause problems? I am thinking about disconnecting everything, then re-leveling the pad...I'm worried the pipes may not fit exactly if I do that though.
    Should I leave the pad uneven?
    Thanks
    Pierre
    2012 36K IG Plaster pool,DE Filter Model DEV60 , pump Model PHPF2.0, Polaris 380 Cleaner, Jandy PS-6 controller
    Testkit is LaMotte ColorQ Pro 7 Plus + Taylor K-2006
    Stenner pump replaced my Nature2 Fusion
    Pool has attached Spa 7ft Radius
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Equipment pad NOT level...will it be a problem?
    Not an issue. Happens plenty of times that pads sink and aren't level any more.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
