Thread: Intex sf20110 not pumping
    Jul 2015
    Temple, Tx
    5
    My pool has been closed since October. Finally getting around to opening it now. When I turn the pump on it just buzzes loudly and does nothing else. I found no evidence of debris clogging openings. We just got the system a year ago and it has not been used much. I did not run it at all while the pool was closed. Anybody know what could be wrong with the pump?
    Intex above ground 12x24 with sf20110 sand filter and salt water system
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Re: Intex sf20110 not pumping
    When my pump buzzed, it needed a new capacitor. I got one at a local electrical supply (took the old one off and took it with me). Worked like a charm. You might see if that works, it was fairly cheap, about $10 bucks.
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Jul 2015
    Temple, Tx
    5
    Ok, thanks Sandra! I appreciate it!
