Thread: Filter cartridge keeps getting clogged every couple days
    Jul 2015
    redding
    2
    So, I think that I am doing a decent job keeping the pool clean- my levels had been fine for awhile, then I went on a vacation. The past couple weeks, the filter cartridges have started getting clogged within a couple of days of putting them in. When I came back from vacation, there was a bit of algae in the pool. I have cleaned it all out, and put quite a bit of cholorine in the floaters and the skimmer. The pool looks a little cloudy still, and the cartridge that I put in yesterday was clogged last night. Could it be algae still in there?? How do I take care of this and what products should I be using to treat that? Should I go get more algaecide? Help please!!!
    Intex Ultra Frame above ground pool
    4.3 ft deep, 22 feet diameter
    Krystal Clear Model 633T Filter Pump
    Jun 2014
    14,970
    Re: Filter cartridge keeps getting clogged every couple days
    Hello and welcome to TFP!. Your situation sounds much like those who trusted pool store advice. We've all been there. If you have algae (and it sounds like you do), then it's everywhere - to include your filter which probably needs constant cleaning. But cleaning the filter won't resolve your algae. Only the proper testing and chemical balance will so that. We need to know a couple things first:
    1 - What test kit do you have?
    2 - Post a set of your test results (FC, CC, CYA, PH, TA, and CH)
    3 - Confirm if your filter is cartridge or Sand
    Definitely do not put any algaecide or other pool store products in your pool. Save your money. Focus on liquid bleach and read the SLAM link below in my signature to get acquainted with what is coming. We'll look for your reply to assist you farther. Welcome to TFP!
    Oh, and floaters, tablets, pucks need to come out right away. They increase CYA to a bad level.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,390
    Pat (Texas Splash) has you covered. We can help.
    Kim
