Thread: Hi there!
    Jul 2015
    redding
    2
    Hi there!
    I am new to this site- I have an above ground Intex Ultra Frame and am loving it!! Just need a little help understanding the best way to keep everything clean and working properly!
    Intex Ultra Frame above ground pool
    4.3 ft deep, 22 feet diameter
    Krystal Clear Model 633T Filter Pump
    Jun 2014
    14,987
    Re: Hi there!
    Welcome to TFP! Your best bet right now is to get acquainted with the vital links you see below, and/or the Pool School page. Also, if you don't have one already, the best thing you can do for your pool is get the right test kit. Please see the TF-100 link below for options. That should be priority #1.
    Golden rule - Avoid the pool store for testing, advice, or products. You simply won’t get the advice/service you deserve and you will waste money on products your pool doesn’t need. Do not add anything to your pool other than what is advocated by the TFP site or its experts. You’ll have a happier pool, spend less time maintaining your pool, and probably save some $$ in the process. The following are short articles from this site that you will see linked in my signature below: Pool School, Recommended Levels (for YOUR pool), PoolMath Calculator, SLAM, and the Chlorine/CYA Chart.
    We're happy to have you with us.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hi there!
    Welcome to TFP!
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
