Results 1 to 9 of 9
Thread: Tiny air bubbles
    Jun 2015
    mexico
    18
    Tiny air bubbles
    Good afternoon I have a 21 foot pool above ground that we replace the liner in this year and ever since I replaced the liner and hooked everything up I now have all these tiny little air bubbles throughout my entire pool along the sides all on the bottom I'm wondering if its due to the fact that I have no flow control on the return valve as of right now its just blowing into the center of the pool we're not going in a circle around the pool so I'm wondering if it has anything to do with that any help would be appreciated thanks
    Jun 2015
    mexico
    18
    Re: Tiny air bubbles
    Quote Originally Posted by Kdirect2014 View Post
    Sent from my XT907 using Tapatalk
    This is what the bubbles look like all over the pool.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Do you have a SWG?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2015
    mexico
    18
    What is a swg??
    Jun 2014
    15,253
    SWG is a Salt Water Generator. We like to know the equipment in your pool and how it is configured since that may help answer some questions.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I asked if you have a SWG because mine after a few hours working, most of the walls in my pool are full of little bubbles. Its normal
    Jun 2015
    mexico
    18
    Quote Originally Posted by Texas Splash View Post
    I have a Hayward sand filter and a Hayward pump and a lomart skimmer.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    You might have a suction leak. Is the water level in the skimmer to low? Also do you see the water vortex inside the skimmer. If so it could be drawing air in at the point. When you shut off the pump is there water leaking anywhere? If water is leaking on the suction side that will be the source of the air when it is running.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2015
    mexico
    18
    Okay will check. Thanks.
