Results 1 to 7 of 7
Thread: Advice needed - Return plumbing on pool deck.
    May 2011
    Loveland, Colorado
    16
    We decided two years ago that the water loss from the pool was on the return side. 3,000G a day! So, we plugged the jets and ran a fire hose from the pump to the far end of the pool. Works great; looks horrible!
    We want to run 2" PVC on the deck and T out some returns down into the pool to circulate water better. Does anyone have advice on how to step down the PVC in diameter to make the jets work the best? Do we T off with 2" and the step down to 1" into the pool? Or, should we go with 3/4" into the pool? We think it needs three jets - just like the inground lines were. And how far down into the water should the jets be?
    20x40 Gunite
    45,000G
    Resurfaced in 2005 with Epoxy Glass
    Hayward Super II
    Re: Advice needed - Return plumbing on pool deck.
    Why not cut the concrete deck in some places and plumb it in underground with the proper jets?
    May 2011
    Loveland, Colorado
    16
    We simply don't have the funds to do that again. It was done 12 years ago, for $15,000...and failed in 10 years.
    20x40 Gunite
    45,000G
    Hayward Super II
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    What caused the lines to fail? Did they freeze and bust? If you want to run it above ground you could run 2" around and reduce to the standard 1-1/2" return fitting size to put return eyeballs. If you're handy enough to do all the piping yourself, you're probably handy enough to cut the concrete and repair the lines yourself and not spend a fortune again.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by coloexposures View Post
    that sucks, sorry to hear that... you could use 2 inch pipe all the way to the pool..
    lowes will have everything you need to do this
    1. I would probably use a 90 to drop it 12 inches into the water then T it..
    2. use a 90 at the end of each pointing to the other side of the pool
    3. use a short piece of 2 inch pipe into the 90's
    4. use a 2 inch to 1.5 inch threaded coupling ( that way you can use normal returns like this..)
    build the entire part that will be in the pool first and then connect it to the pipe coming to the pool..
    hope this will get you by until you can get a fix that will work
    Jul 2015
    lady lake fl
    14
    Is it one jet or all of them? If it is just one you could cut the leg at the maninfold and cap it, keeping the other returns working. Cut in ball valve on each leg so you can find the bad one. I had a leak in my house plumbing under the slab. I had a guy come out and with a high tech listening device and found the leak within 1" I think it cost me 200 but saved me a ton of time and my slab.
    May 2011
    Loveland, Colorado
    16
    Well, the rub is that there is one pipe running out and around the pool, and it Ts off to 3 jets. There is no manifold. Now I'm assuming they did all of that wrong when we had it re-plumbed. Grrrr. It 'is' one jet, I'm pretty sure...so, perhaps I could dig down to that one and cap the T. That's a good idea. And, I didn't know about the listening device; that's cool. Thank you! Thank you to everyone who has offered advice; I really appreciate it.
    20x40 Gunite
    45,000G
    Hayward Super II
