Thread: Defective Pentair 261186 Multi-valve WARNING
    Sep 2014
    Honduras
    12
    I'm convinced that the Pentair 261186 Multi-valve is a defective product.
    We used this valve as a replacement on an AquaTools AT3115 sand filter after the spider gasket in the original valve gave way. After two months, all the dirt (not filter sand) when vacuuming was coming right back in through the jets. I replaced the spider gasket twice with no luck, and Amazon thoughtfully sent another valve, which failed at 8 weeks of use.
    Amazon.com : Pentair 261186 Valve Replacement Sta-Rite Cristal-Flo High-Rate Pool and Spa Sand Filter : Outdoor Spas : Patio, Lawn Garden
    Here's a pic. I used floculant and opened up the return in the smaller separate part of the pool, so that the two jets in the main part of the pool had minimal pressure. Essentially, all the "filtered" water goes here first:
    Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
    It's a 4500 gallon in-ground concrete/tile pool with a 1hp pump. If anyone has any ideas I'd love to hear them. I've backwashed, deep-cleaned, ect. to no avail.
    Drew
    Honduras
    30,421
    Re: Defective Pentair 261186 Multi-valve WARNING
    Sorry you have not received a reply. I cannot help with your issue. Even on this VERY busy forum, there are sometimes questions that no one has a good answer for. Your's might be one of them.
    Sep 2014
    Honduras
    12
    I think it's just a low-quality valve. It's a shame that this is the only one that fits the sand filter!
    Orlando, FL
    690
    My experience has been that if I do not rinse the filter for the same amount of time that I spend backwashing, the junk will blow back into the pool. This is especially true when I have a lot of dead algae in the pool. Once I learned to backwash/rinse in alternating cycles I have never had junk blowing back into the pool. If the valve is truly bad and it is not functioning properly I suppose a completely new filter is in order.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Sep 2014
    Honduras
    12
    I'd like to cross-post this in the Reviews section.
