Thread: Knowing is half the battle
    Feb 2009
    Honolulu
    8
    Finally found this site after surfing the poolforum for a while. I have already drastically increased my pool knowledge and have saved a ton of $$ by not having to go to the pool store to buy inflated chemicals and salt.
    Thank you very much!
    I have even become brave enough to conduct an ascorbic acid treatment. It's in progress right now. I'm hoping to see a nice white pool surface when I get home. I posted some more details in one of mbar's threads.
    I know it's the winter season in most of the country, but here in Hawaii it's still the pool season.
    /z
    Re: Knowing is half the battle
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome Z
    You're done SLAMing when:
