Thread: Jandy RS-PS4 Wiring
    Mar 2015
    South Florida
    43
    Jandy RS-PS4 Wiring
    I am trying to install a regular 120v outlet and be able to turn it on/off remotely. I was hoping that this was as simple as wiring the outlet to Aux 3 for example, but, when I activate Aux 3 there is no electricity on the relay connectors. Any hint?
    12K gallons, IG, Durazzo, Pentair cartridge filter, Jandy ePump JEP2.0 VSP , Pool started March 2, 2015, South FL
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Re: Jandy RS-PS4 Wiring
    One side of the Aux 3 relay contact must be fed from a 120v circuit.
    26700 gal, vinyl, SWG, Hayward Goldline controls, T-15 Cell, 20gpm/ft2 sand filter, 1 hp pump
    Mar 2015
    South Florida
    43
    It make sense, thanks Knjakeman for the hint. The relay has two line terminals (input voltage) and two load terminals (equipment or outlet). Now I have to figure it out, where to get the 120v inside the panel.
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    That should come from a circuit breaker to the input. Do you have any spare circuit breakers ?
    Knj
    Mar 2015
    South Florida
    43
    I have the space, but not the circuit breaker. I was just getting the info to go and buy one.
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Cool, I think you got this by the horns !!
    Knj
