Thread: Hard plumbed Intex pool-small leak at eyeball
    I hard plumbed my outlet from my SWG to the pool return so I could add a DIY solar heater. It went much better than I had anticipated, but I have a small leak where the box nut adapter connects to the eyeball return. I noticed the gasket at that joint is different from the others and has a ridge in it that corresponds with the plunger valve. Any ideas to stop the leak?
    Thanks in advance.
    Re: Hard plumbed Intex pool-small leak at eyeball
    http://www.intexcorp.com/10745.html?You could order a gasket from intex that has the little ridge. or maybe run a bead of silicone around it?
    G
