Results 1 to 16 of 16
Thread: New deck walkway extension
    Jul 2014
    Oakbank, Canada
    389
    Finally got around to building that new walkway extending the deck to the pool. Now no one has to walk across the grass to get into the pool, and that mean no more more grass in the pool either.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: New deck walkway extension
    Now that is a nice upgrade!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    Nice work! SO who was the first one to run off of the ramp and jump into the pool?????? LOL
    Look at that clear water! Good job!
    Kim
    Cypress, Tx.
    154
    that looks great. I extended my deck also. Got tired of the kids and their friends dragging in dirt/mud.
    Is that a solar water heater in your photos?
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    Jul 2014
    Oakbank, Canada
    389
    [QUOTE=
    Is that a solar water heater in your photos?[/QUOTE]
    Yes, I have a total of 8' x 20' in panels.
    No one yet, they have all been warned not to.
    Quote Originally Posted by kimkats View Post
    Kim
    Jul 2012
    Tallahassee, FL
    30,492
    LOL I sure hope they "follow the rules" as them jumping into the side of the pool could cause a lot of damage!
    Kim
    Jul 2014
    Oakbank, Canada
    389
    Yup, but no no worse than jumping off the old ladder, which was not allowed either. Just have to keep an eye on everyone.
    Kim
    Cypress, Tx.
    154
    if I had a heater like that herre in Tx, we would be boiling the water
    Jul 2014
    Oakbank, Canada
    389
    Just keeps mine at around 82 right now with all the cloud and smoke in the sky from forest fires few hundred miles to the west of us. We have not seen the sun for almost 2 weeks now.
    Cypress, Tx.
    154
    No Sun, that's bad. Hope it clears up for you soon. It's just hotter than blazes and between 75 and 95% humidity here in Houston.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    I would have made it higher than the pool rail. Then lay some plastic across the walkway and make a slip-n-slide.
    Casey's Avatar
    SW PA
    10,444
    lol That sounds like so much fun til someone gets hurt!
    Your walkway looks great!
    Jul 2014
    Oakbank, Canada
    389
    Thanks for the compliments, pool season is so shot here, trying to make the best of it.
    Jul 2015
    Shenandoah Valley, VA
    9
    Looks great! Do you leave your pool up year round? I want to build a small deck of some sorts but I am planning on taking my pool down at the end of the season. Looks like that would be easy to work around if you take it down.
    Jul 2014
    Oakbank, Canada
    389
    No, we take it down every fall due to our winters being -35. Those here with steel walled pools leave them up, but I have not been brave enough to leave the Ultra up. Seems every one we see that was left up here had damage come spring, ripped liners, etc.
    Once its drained, only takes me less than 2 hours to dry it, and pack it all away, so its not too bad of an ordeal. Just more of a pain in the rear than anything come spring putting it all back up.
    Jun 2014
    15,109
    Nice work and creative way of getting access to the pool with having to build a completely new decking. You tied it in very nicely. I agree with Richard .... lay some plastic down and put a ramp at the end. Just not so high that anyone can over-shoot.
