Results 1 to 7 of 7
Thread: Landscaping Bricks Around Pool Are Loose
    Jul 2015
    Birmingham, AL
    39
    Anyone else having trouble with their landscaping pool bricks coming loose each year? Every year, there are about 5 of these that come loose and I put down landscaping adhesive and research the ones that are best, but it still happens with different bricks each year. One suggestion was that the adhesive needed some kind of sealant since it was so close to the pool water. Any help would be great. Thanks
    Installed 2010: 18X36X6ft 29000 gls, SWG, Vinyl Liner, Sand Filter. 2 skimmers/returns, Polaris cleaner aka Arthur, Heater
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,635
    Re: Landscaping Bricks Around Pool Are Loose
    No real idea but wonder if the ones that come loose are ones that people have grabbed and hung onto for some reason?
    Do they stay after you put new stuff on them?
    Kim
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    What is underneath them? Just wondering if it was cement slab that you could use some thinset to hold them in place. Have you tried liquid nails?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    What about paver adhesive? Comes in a caulk tube made my loctite and liquid nails. Lowes sells it.
    Jul 2015
    Birmingham, AL
    39
    There is a hard surface underneath that is a hard plastic or polymer that the bricks make contact with. All of those adhesives are the ones that I've tried, but I have the same issue with random ones coming loose again when I open the pool each year.
    The polymer they are glued to is the top of the pool side wall. When they pop up is the old adhesive stuck to the plastic or the paver? Plastic is not the ideal material to glue pavers too. You may be stuck with finding the best exterior adhesive you can that hopefully says it adheres to both plastic and concrete. Using it you might just have to resign yourself to resetting a few every year.
    18' x 36' saltwater inground vinyl pool
    Jul 2015
    Birmingham, AL
    39
    There is adhesive on both but mostly is the plastic. If adhering it to that is the problem, maybe putting more adhesive on the sides of the brick would work better? You're probably right, this is just something that I've gotta deal with. I've read other posts about people dealing with this with no solution found (don't remember where though), so you'd think it'd be a more common problem.
