Results 1 to 7 of 7
Thread: New to the forum
    Atwork's Avatar
    Jul 2015
    Marietta/ GA
    7
    New to the forum
    Wanted to introduce myself. Have viewed the forum from afar and decided to jump in. 5th year with pool. 1st year using liquid Chlorine.
    33K Gal Plaster Kidney bean shaped Pool, 2 HP Pentair Superflo, Hayward 244S Sand Filter. Pool built in 1984.
    Taylor K2006 Testing
    Marietta, GA
    Aug 2013
    Arab, Alabama
    422
    Re: New to the forum
    Welcome to TFP!
    Pool...check
    Taylor 2006...check
    Bleach...check
    Found TFP...check
    Posted a full set of results...
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP! 2015 is going to be a good year!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    welcome
    Atwork's Avatar
    Jul 2015
    Marietta/ GA
    7
    First Test
    FC - 6.5
    CC - 0.5
    PH - 7.4
    TA - 100
    CYA - 55
    CH - 320
    At the end of a SLAM. Pool has just a bit of haze in the deep end. But clearing rapidly.
    Marietta, GA
    Jun 2014
    15,189
    Those are some rock-sold numbers for sure! Now just make sure that GA sun doesn't gobble-up your FC and you'll be fine. Nice to have you "jump-in" with us. CANNONBALL!
    Atwork's Avatar
    Jul 2015
    Marietta/ GA
    7
    Quote Originally Posted by Texas Splash View Post
    What is funny is i had my pooled "tested" by the local Leslie's Yesterday AM. Told me my CYA was 99 and good. Asked me if i wanted to be entered in the Algea free garauntee and i declinded. the only test portion they did get correct was the CL.
    Glad to start testing on my own. Also, i did test the water 3 times in the same location to confirm my test results. Had flashbacks to Chem Lab 2 and Organic Chem.
    Marietta, GA
